주요 콘텐츠로 건너뛰기
Acer Spin 3 SP315-51-79NT Touch Screen Replacement
필요한 것
  1. Acer Spin 3 SP315-51-79NT Touch Screen Replacement, Back Panel: 1 단계, 이미지 1/2 Acer Spin 3 SP315-51-79NT Touch Screen Replacement, Back Panel: 1 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove twelve (12) screws from the back panel.
  2. Acer Spin 3 SP315-51-79NT Touch Screen Replacement: 2 단계, 이미지 1/2 Acer Spin 3 SP315-51-79NT Touch Screen Replacement: 2 단계, 이미지 2/2
    • Gently pry the back plate off with your fingers.
  3. Acer Spin 3 SP315-51-79NT Touch Screen Replacement, Screen Assembly: 3 단계, 이미지 1/2 Acer Spin 3 SP315-51-79NT Touch Screen Replacement, Screen Assembly: 3 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove a total of four screws from the hinges (two on each hinge).
  4. Acer Spin 3 SP315-51-79NT Touch Screen Replacement: 4 단계, 이미지 1/2 Acer Spin 3 SP315-51-79NT Touch Screen Replacement: 4 단계, 이미지 2/2
    • Remove wires connecting to motherboard.
    • You can then simply pull the two halves of the computer away from each other.
  5. Acer Spin 3 SP315-51-79NT Touch Screen Replacement, Touch Screen: 5 단계, 이미지 1/2 Acer Spin 3 SP315-51-79NT Touch Screen Replacement, Touch Screen: 5 단계, 이미지 2/2
    • Use a spudger to separate the plastic cover from the screen assembly.
    • Do not use a metal spudger for this step. The metal spudger should only be used for serious prying power. When used incorrectly, the metal spudger can cause serious damage to the internal components (especially glass) in the device.
  6. Acer Spin 3 SP315-51-79NT Touch Screen Replacement: 6 단계, 이미지 1/2 Acer Spin 3 SP315-51-79NT Touch Screen Replacement: 6 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the four screws securing the touch screen to the rest of the assembly.
  7. Acer Spin 3 SP315-51-79NT Touch Screen Replacement: 7 단계, 이미지 1/1
    • Flip over the touch screen to reveal the circuit board.
    • Disconnect the cable from the circuit board and completely remove the touch screen from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nolan Martinous
회원 가입일: 10/25/21
324 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-1, Sinclaire Fall 2021 UMass Dartmouth, Team 2-1, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S2G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 40
전체 시간: 1,897
