소개
Is the touch screen not working or recognizing input? If so, the touchscreen may be faulty and needs to be replaced. Follow the instructions in this guide to remove and replace the touchscreen in the Acer Spin 3 SP315-51-79NT laptop.
필요한 것
Using the Phillips #1 screwdriver, remove twelve (12) screws from the back panel.
Using the Phillips #1 screwdriver, remove a total of four screws from the hinges (two on each hinge).
다른 3명이 해당 안내서를 완성하였습니다.
