주요 콘텐츠로 건너뛰기
Acer Spin 5 N17W2 Motherboard Replacement
필요한 것
  1. Acer Spin 5 N17W2 Motherboard Replacement, Cooling Fan: 1 단계, 이미지 1/2 Acer Spin 5 N17W2 Motherboard Replacement, Cooling Fan: 1 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove six 6 mm screws.
    • Use the same screwdriver to remove six 5mm screws.
  2. Acer Spin 5 N17W2 Motherboard Replacement: 2 단계, 이미지 1/1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove two 5 mm screws by using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Motherboard Replacement: 4 단계, 이미지 1/2 Acer Spin 5 N17W2 Motherboard Replacement: 4 단계, 이미지 2/2
    • Use two opening tools to disconnect the cooling fan from the motherboard.
    • Remove the fan from the device.
  5. Acer Spin 5 N17W2 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • Remove four 5 mm screws using the Phillips #1 screwdriver.
  6. Acer Spin 5 N17W2 Motherboard Replacement: 6 단계, 이미지 1/1
    • Take off the black heat sink (be careful of the grey thermal grease).
  7. Acer Spin 5 N17W2 Motherboard Replacement: 7 단계, 이미지 1/3 Acer Spin 5 N17W2 Motherboard Replacement: 7 단계, 이미지 2/3 Acer Spin 5 N17W2 Motherboard Replacement: 7 단계, 이미지 3/3
    • Remove all peripherals connecting to the motherboard.
    • Remove the second chip.
    • Remove the wireless LAN chip.
  8. Acer Spin 5 N17W2 Motherboard Replacement: 8 단계, 이미지 1/1
    • Disconnect the three connection wires.
  9. Acer Spin 5 N17W2 Motherboard Replacement: 9 단계, 이미지 1/2 Acer Spin 5 N17W2 Motherboard Replacement: 9 단계, 이미지 2/2
    • Take off the connecting port with black tape.
    • Take off the last port with purple tape.
  10. Acer Spin 5 N17W2 Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the motherboard from the device.
결론
He Kai
회원 가입일: 10/04/19
289 평판
안내서 2개 작성하였습니다
댓글 2개
I need the motherboard where I can buy it..
john fredy mendoza torres - 답글
I need the motherboard where I can buy it please...
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 1,451
