주요 콘텐츠로 건너뛰기
Acer Spin 5 N17W2 Screen Assembly Replacement
필요한 것
  1. Acer Spin 5 N17W2 Screen Assembly Replacement, Screen Assembly: 1 단계, 이미지 1/2 Acer Spin 5 N17W2 Screen Assembly Replacement, Screen Assembly: 1 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove the six 6mm screws.
    • Use Phillips #1 screwdriver to remove six 5mm screws.
  2. Acer Spin 5 N17W2 Screen Assembly Replacement: 2 단계, 이미지 1/1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Screen Assembly Replacement: 3 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to remove the three 5mm screws.
    • Use the Phillips #1 screwdriver to remove the three 5mm screws on another side of hinge.
  4. Acer Spin 5 N17W2 Screen Assembly Replacement: 4 단계, 이미지 1/1
    • Disconnect chips from the two end side of hinge.
  5. Acer Spin 5 N17W2 Screen Assembly Replacement: 5 단계, 이미지 1/1
    • Use the plastic opening tool to pry the hinge up.
  6. Acer Spin 5 N17W2 Screen Assembly Replacement: 6 단계, 이미지 1/1
    • Remove the wireless LAN chip from the motherboard.
  7. Acer Spin 5 N17W2 Screen Assembly Replacement: 7 단계, 이미지 1/1
    • Detach the sensors on each side of the hinge from the motherboard.
  8. Acer Spin 5 N17W2 Screen Assembly Replacement: 8 단계, 이미지 1/1
    • Detach the screen assembly from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
YUJIE WANG
회원 가입일: 10/04/19
490 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 24
전체 시간: 2,547
