주요 콘텐츠로 건너뛰기
Acer Spin 5 N17W2 Trackpad Replacement
필요한 것
  1. Acer Spin 5 N17W2 Trackpad Replacement, Battery: 1 단계, 이미지 1/2 Acer Spin 5 N17W2 Trackpad Replacement, Battery: 1 단계, 이미지 2/2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
  2. Acer Spin 5 N17W2 Trackpad Replacement: 2 단계, 이미지 1/1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Trackpad Replacement: 3 단계, 이미지 1/1
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Trackpad Replacement: 4 단계, 이미지 1/1
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 Trackpad Replacement: 5 단계, 이미지 1/1
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 Trackpad Replacement: 6 단계, 이미지 1/1
    • Remove the battery from the device.
  7. Acer Spin 5 N17W2 Trackpad Replacement, Trackpad: 7 단계, 이미지 1/1
    • Using the blue spudger, pry the two black clips from the two ribbon cables on the bottom of the mouse pad.
  8. Acer Spin 5 N17W2 Trackpad Replacement: 8 단계, 이미지 1/1
    • Remove ribbon cables connected to the middle of the mouse pad.
    • Remove the adhesive tape from the left side of the mouse pad.
  9. Acer Spin 5 N17W2 Trackpad Replacement: 9 단계, 이미지 1/1
    • Using the phillips #1 screwdriver, remove the 4 screws securing the mouse pad.
  10. Acer Spin 5 N17W2 Trackpad Replacement: 10 단계, 이미지 1/1
    • Using your thumbs, push the mouse pad from the inside of the computer towards ur self and slide the mousepad out of the computer.
결론
William
회원 가입일: 02/20/20
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 749
