주요 콘텐츠로 건너뛰기
Acer Spin 5 SP513-51-57TP Cooling Fan Replacement
필요한 것
  1. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Flip your laptop over so that the model sticker is facing upward towards the ceiling.
    • Make sure your computer is turned off before starting to avoid getting shocked.
  2. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 2 단계, 이미지 1/2 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
  3. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 3 단계, 이미지 1/3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 3 단계, 이미지 2/3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 3 단계, 이미지 3/3
    • Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
    • Do not use any metal tools to pry open the device.
    • It is recommended that you start from one corner and run the tool along the edges of your laptop from corner to corner for a safe removal.
  4. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 4 단계, 이미지 1/3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 4 단계, 이미지 2/3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 4 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
  5. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 5 단계, 이미지 1/3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 5 단계, 이미지 2/3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 5 단계, 이미지 3/3
    • Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
    • Remove the battery from the case.
  6. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: 6 단계, 이미지 1/3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: 6 단계, 이미지 2/3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: 6 단계, 이미지 3/3
    • Use Phillips #1 screwdriver to remove the two 4mm screws that are securing the fan.
  7. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 7 단계, 이미지 1/2 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 7 단계, 이미지 2/2
    • Using Phillips #1 screwdriver remove three 5 mm screws to remove the heatsink.
    • When removing the cooling fan, the heatsink component will stay connected.
  8. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 8 단계, 이미지 1/3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 8 단계, 이미지 2/3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: 8 단계, 이미지 3/3
    • Using your hand, pull out wiring harness to disconnect the fan from the motherboard.
    • Lift the fan out of the case to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anthony Vansell
회원 가입일: 01/24/20
872 평판
안내서 5개 작성하였습니다
Hufflepuff Hufflepuff 회원
Local Repair Groups
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 12
전체 시간: 1,311
