소개
The motherboard holds together many of the crucial components of your computer. If your motherboard is failing your computer will display an error code with a series of audible beeps. It will also display the “Blue Screen of Death” representing it has failed.
Motherboard: Definition. A motherboard is one of the most essential parts of a computer system. It holds together many of the crucial components of a computer, including the central processing unit (CPU), memory and connectors for input and output devices.
Common symptoms of motherboard issues are similar to CPU problems: The system does not display anything; an error code appears; one or more beeps occur; the system locks; the system reboots; a Windows BSOD (blue screen of death) appears; or one or more of the ports, expansion slots, or memory modules fails.
필요한 것
Flip your laptop over so that the model sticker is facing upward towards the ceiling.
Grasp the CMOS battery with the tweezers and remove it from the motherboard.
Using a Phillips #1 screwdriver, remove the one 4mm screw that secures the Solid State Drive.
Use Phillips #1 screwdriver to remove the two 4mm screws that are securing the fan.
Use the tweezers to disconnect the wiring harness in the bottom right corner of your laptop.
댓글 한 개
I was wondering if the CPU is soldered to the motherboard? Is it possible to remove the CPU and replace it with an upgraded CPU?
