주요 콘텐츠로 건너뛰기
Acer Spin 5 SP513-51-57TP Solid State Drive Replacement
필요한 것
  1. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip your laptop over so that the model sticker is facing upward towards the ceiling.
    • Make sure your computer is turned off before starting to avoid getting shocked.
  2. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 2 단계, 이미지 1/2 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
  3. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 3 단계, 이미지 1/3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 3 단계, 이미지 2/3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 3 단계, 이미지 3/3
    • Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
    • Do not use any metal tools to pry open the device.
    • It is recommended that you start from one corner and run the tool along the edges of your laptop from corner to corner for a safe removal.
  4. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 4 단계, 이미지 1/3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 4 단계, 이미지 2/3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 4 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
  5. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 5 단계, 이미지 1/3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 5 단계, 이미지 2/3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 5 단계, 이미지 3/3
    • Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
    • Remove the battery from the case.
  6. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement, Solid State Drive: 6 단계, 이미지 1/3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement, Solid State Drive: 6 단계, 이미지 2/3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement, Solid State Drive: 6 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove the one 4mm screw that secures the Solid State Drive.
  7. Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 7 단계, 이미지 1/3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 7 단계, 이미지 2/3 Acer Spin 5 SP513-51-57TP Solid State Drive Replacement: 7 단계, 이미지 3/3
    • Use your hand to pull out the Solid State Drive from the motherboard.
    • You will be pulling the solid state drive out to the left, as it will be connected to the port on the motherboard on its right side. This is opposite the direction that the pictures depict it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anthony Vansell
회원 가입일: 01/24/20
872 평판
안내서 5개 작성하였습니다
Hufflepuff Hufflepuff 회원
Local Repair Groups
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 29
전체 시간: 1,903
