소개
If the USB and/or side ports of your Acer Spin 5 SP515-51GN-807G are malfunctioning or not working at all, use this guide to replace the USB and side ports.
The USB ports can be used to connect a mouse to the laptop or charge other devices. If you notice that the ports aren’t working and connecting to other devices, it could be due to debris build-up or broken ports.
A cause inoperative side ports could be due to a blockage caused by dust or other debris. It is possible to try and remove the dust using a dust blower.
Always remember to power down the device before beginning replacement.
필요한 것
Remove the eleven 6.5 mm screws that secure the back case using a Phillips #1 screwdriver.
Using tweezers, remove the piece of black tape over the battery cable connector.
Using tweezers, carefully grip the sensor cable by the white and red tab.
Using gentle pressure, remove the cable from its connection by pulling outward.
