주요 콘텐츠로 건너뛰기
Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement
필요한 것
  1. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Battery: 1 단계, 이미지 1/3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Battery: 1 단계, 이미지 2/3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Battery: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using tweezers, remove the piece of black tape over the battery cable connector.
  2. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 2 단계, 이미지 1/3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 2 단계, 이미지 2/3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 2 단계, 이미지 3/3
    • Remove the piece of black tape that covers the battery.
  3. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 3 단계, 이미지 1/2 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 3 단계, 이미지 2/2
    • Grip the battery cable on both sides with your fingertips and gently pull it away from the port.
    • If needed, use the plastic opening tool to remove the cord from its port.
  4. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 4 단계, 이미지 1/3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 4 단계, 이미지 2/3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 4 단계, 이미지 3/3
    • Remove the two 3.5 mm screws that secure the battery using a Phillips #00 screwdriver (PH00 bit).
  5. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 5 단계, 이미지 1/2 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 5 단계, 이미지 2/2
    • Carefully place your fingers under the plastic lip where the screws were removed.
    • Lift upwards to remove the battery.
    • Do not bend or puncture the lithium ion battery as it poses a fire hazard.
  6. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Wireless (WiFi) Card: 6 단계, 이미지 1/3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Wireless (WiFi) Card: 6 단계, 이미지 2/3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement, Wireless (WiFi) Card: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using tweezers, remove the sticker that covers the connection between the wireless card and motherboard.
  7. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 7 단계, 이미지 1/2 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 7 단계, 이미지 2/2
    • Remove the 6.5 mm screw that secures the wireless card using a Phillips #00 screwdriver (PH00 bit).
  8. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 8 단계, 이미지 1/2 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 8 단계, 이미지 2/2
    • Gently pull the wireless card away from the motherboard.
  9. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 9 단계, 이미지 1/3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 9 단계, 이미지 2/3 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 9 단계, 이미지 3/3
    • Using your fingers, carefully pull the white wire upwards, removing it from the terminal of the wireless card.
  10. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 10 단계, 이미지 1/2 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 10 단계, 이미지 2/2
    • Repeat the previous step but this time for the black wire.
  11. Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 11 단계, 이미지 1/2 Acer Spin 5 SP515-51GN-807G Wireless (WiFi) Card Replacement: 11 단계, 이미지 2/2
    • Remove the wireless (WiFi) card from the laptop.
결론
James Wasielewski
회원 가입일: 01/24/20
1,042 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 27
전체 시간: 1,554
