주요 콘텐츠로 건너뛰기
Acer Spin 7 SP714-51 Solid State Drive Replacement
필요한 것
  1. Acer Spin 7 SP714-51 Solid State Drive Replacement, Solid State Drive: 1 단계, 이미지 1/1
    • Turn the laptop so that the back cover is visible and facing you. Make sure it is on a flat surface such as a table.
    • Use a Phillips #0 screwdriver to remove the 6 mm screws along the edge of the bottom cover.
  2. Acer Spin 7 SP714-51 Solid State Drive Replacement: 2 단계, 이미지 1/1
    • You can now remove the back panel using your fingers or a spudger.
  3. Acer Spin 7 SP714-51 Solid State Drive Replacement: 3 단계, 이미지 1/1
    • Carefully unplug the battery connector so the laptop is safer to work with.
    • Make sure you pull it straight back.
  4. Acer Spin 7 SP714-51 Solid State Drive Replacement: 4 단계, 이미지 1/1
    • Once the back is open and the battery is disconnected, you should be able to see the SSD on the top right of the laptop if oriented as seen in the photo.
    • The removal of the SSD should be simple as there is only one 6 mm PH0 Phillips screw holding it in place.
    • Once the screw is removed, you may safely remove the SSD and replace it with your new one.
결론
Zach Desrosiers
회원 가입일: 03/22/22
565 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 회원
UMASSD-SINCLAIRE-S22S7G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 44
전체 시간: 1,028
