주요 콘텐츠로 건너뛰기
Acer Spin 7 SP714-51 Wi-Fi Card Replacement
필요한 것
  1. Acer Spin 7 SP714-51 Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 1/3 Acer Spin 7 SP714-51 Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 2/3 Acer Spin 7 SP714-51 Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 3/3
    • Turn the laptop so that the back cover is visible and facing you. Make sure it is on a flat surface, such as a table.
    • Using a standard PH0 Phillips-head screwdriver, work your way around the edge removing the 6mm screws along the way.
    • Once all the screws are removed, you should easily be able to remove the back cover. This can be done by hand or by using a Spudger as seen in the tools list.
    • Once the back cover is removed, make sure you disconnect the battery cable.
  2. Acer Spin 7 SP714-51 Wi-Fi Card Replacement: 2 단계, 이미지 1/1
    • Disconnect the white and black antennae from the Wi-Fi card.
    • The Wi-Fi card is located on the left side of the laptop when it is flipped to see the bottom of the laptop.
    • The antennae should snap off upwards easily with a pry tool so the antennae and Wi-Fi card no longer connect.
  3. Acer Spin 7 SP714-51 Wi-Fi Card Replacement: 3 단계, 이미지 1/2 Acer Spin 7 SP714-51 Wi-Fi Card Replacement: 3 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the 6 mm retaining screw from the Wi-Fi card, and carefully pull the card free to remove it from the laptop.
결론
Zach Desrosiers
회원 가입일: 03/22/22
565 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 회원
UMASSD-SINCLAIRE-S22S7G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 17
전체 시간: 244
