주요 콘텐츠로 건너뛰기
Acer Spin SP513-52N Charging Port Replacement
필요한 것
  1. Acer Spin SP513-52N Charging Port Replacement, Charging Port: 1 단계, 이미지 1/1
    • Power off your laptop before beginning disassembly and disconnect the device from the charger.
    • Use a Phillips #0 screwdriver to remove twelve 6.0 mm screws from the back panel.
  2. Acer Spin SP513-52N Charging Port Replacement: 2 단계, 이미지 1/2 Acer Spin SP513-52N Charging Port Replacement: 2 단계, 이미지 2/2
    • Use an opening tool in the seam of back case and slide it around the perimeter to release the clips securing it to the top case.
    • Remove the back case to reveal the internals of the laptop.
  3. Acer Spin SP513-52N Charging Port Replacement: 3 단계, 이미지 1/2 Acer Spin SP513-52N Charging Port Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Before replacing the charging port, unplug the internal battery from the motherboard.
    • Unplug the broken charging port from the motherboard with tweezers.
  4. Acer Spin SP513-52N Charging Port Replacement: 4 단계, 이미지 1/1
  5. Acer Spin SP513-52N Charging Port Replacement: 5 단계, 이미지 1/2 Acer Spin SP513-52N Charging Port Replacement: 5 단계, 이미지 2/2
    • Use tweezers to insert the new charging port securely.
  6. Acer Spin SP513-52N Charging Port Replacement: 6 단계, 이미지 1/1
    • Place the back case onto the laptop and press down around the edges of the perimeter.
    • You should hear the clips snap together.
  7. Acer Spin SP513-52N Charging Port Replacement: 7 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to fasten the twelve 6.0 mm screws back into place.
결론
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%). Take your e-waste to an R2 or e-Stewards certified recycler.
Sara Al-Shumari
회원 가입일: 01/10/21
145 평판
안내서 1개 작성함
York University, Team B-4, Allen Fall 2022 York University, Team B-4, Allen Fall 2022 회원
YORK-ALLEN-F22SBG4
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 33
전체 시간: 1,204
