소개
If your computer has been acting up recently. Every time you turn it on, it shuts down after just a minute or two, and we've noticed there's no sound during this process. We suspect the fan might not be working properly, causing the system to overheat. Let's explore this issue further, to keep our computer running smoothly you should follow the guide to replace the heat sink/fan.
필요한 것
Use a Torx T5 screwdriver to remove the eleven screws that secure the lower case.
거의 끝나갑니다!
결론
