주요 콘텐츠로 건너뛰기
Acer Swift X N20C12 SSD (Solid State Drive) Replacement
필요한 것
  1. Acer Swift X N20C12 SSD (Solid State Drive) Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the eleven screws that secure the lower case.
  2. Acer Swift X N20C12 SSD (Solid State Drive) Replacement: 2 단계, 이미지 1개 중 1개
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the pick around the perimeter while prying until the lower case releases.
    • Remove the lower case.
  3. Acer Swift X N20C12 SSD (Solid State Drive) Replacement, SSD: 3 단계, 이미지 1개 중 1개
    • The SSD is located to the right of the battery.
  4. Acer Swift X N20C12 SSD (Solid State Drive) Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver end to remove the 5 mm screw that secures the SSD.
  5. Acer Swift X N20C12 SSD (Solid State Drive) Replacement: 5 단계, 이미지 1개 중 1개
    • Gently remove the SSD from the computer by pulling it straight out of its motherboard socket.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
2다른 기여자 명과 함께
Hector
회원 가입일: 06/17/25
427 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 22
전체 시간: 161
