주요 콘텐츠로 건너뛰기
Acer TravelMate P653-V-6882 Mainboard Replacement
필요한 것
  1. Acer TravelMate P653-V-6882 Mainboard Replacement, Battery Pack: 1 단계, 이미지 2개 중 1개 Acer TravelMate P653-V-6882 Mainboard Replacement, Battery Pack: 1 단계, 이미지 2개 중 2개
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Acer TravelMate P653-V-6882 Mainboard Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Acer TravelMate P653-V-6882 Mainboard Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the battery up.
    • Pull out the battery.
  4. Acer TravelMate P653-V-6882 Mainboard Replacement, ODD Module: 4 단계, 이미지 1개 중 1개
    • Slide the ODD module latch down.
    • The ODD module will pop out.
  5. Acer TravelMate P653-V-6882 Mainboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the ODD module.
  6. Acer TravelMate P653-V-6882 Mainboard Replacement, Base Door: 6 단계, 이미지 1개 중 1개
    • Remove the five 7mm Phillips #1 screws.
  7. Acer TravelMate P653-V-6882 Mainboard Replacement: 7 단계, 이미지 1개 중 1개
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  8. Acer TravelMate P653-V-6882 Mainboard Replacement: 8 단계, 이미지 2개 중 1개 Acer TravelMate P653-V-6882 Mainboard Replacement: 8 단계, 이미지 2개 중 2개
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
  9. Acer TravelMate P653-V-6882 Mainboard Replacement, RAM: 9 단계, 이미지 1개 중 1개
    • Locate the two RAM sticks on the bottom of the laptop.
  10. Acer TravelMate P653-V-6882 Mainboard Replacement: 10 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 Mainboard Replacement: 10 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 Mainboard Replacement: 10 단계, 이미지 3개 중 3개
    • Pinch the two metal pieces holding the RAM sticks in place outwards.
    • Holding the sides of the RAM, slide the RAM sticks out.
    • Be careful not to touch the gold connection pins on the RAM sticks, as this could damage the RAM
  11. Acer TravelMate P653-V-6882 Mainboard Replacement, Keyboard: 11 단계, 이미지 1개 중 1개
    • Remove the two 7mm Phillips #1 screws.
  12. Acer TravelMate P653-V-6882 Mainboard Replacement: 12 단계, 이미지 1개 중 1개
    • Flip the laptop so that the underside is now facing the bottom.
    • Open the LCD panel.
    • Use the flat end of a spudger to push in the six latches.
    • Be careful not to bend or crack the keyboard.
  13. Acer TravelMate P653-V-6882 Mainboard Replacement: 13 단계, 이미지 1개 중 1개
    • When the latches are pushed in, the keyboard will pop out.
    • Gently pry up the keyboard.
  14. Acer TravelMate P653-V-6882 Mainboard Replacement: 14 단계, 이미지 1개 중 1개
    • Slide the keyboard forward to access the keyboard cable.
    • Flip the connector latch up to open it.
    • Pull out the keyboard cable gently.
    • Be careful not to damage the connector.
  15. Acer TravelMate P653-V-6882 Mainboard Replacement, Mainboard: 15 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 Mainboard Replacement, Mainboard: 15 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 Mainboard Replacement, Mainboard: 15 단계, 이미지 3개 중 3개
    • Turn the computer over, open the LCD panel, and find the smart card cable connector.
    • Open the smart card cable connector latch.
    • Disconnect the cable.
  16. Acer TravelMate P653-V-6882 Mainboard Replacement: 16 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 Mainboard Replacement: 16 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 Mainboard Replacement: 16 단계, 이미지 3개 중 3개
    • Find the power button launch board cable connector.
    • Open the power button launch board cable connector latch.
  17. Acer TravelMate P653-V-6882 Mainboard Replacement: 17 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 Mainboard Replacement: 17 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 Mainboard Replacement: 17 단계, 이미지 3개 중 3개
    • Find the touchpad and fingerprint board cable connector.
    • Open the touchpad and fingerprint board cable connector’s latches.
    • Disconnect the cables.
  18. Acer TravelMate P653-V-6882 Mainboard Replacement: 18 단계, 이미지 1개 중 1개
    • Using the #1 Phillips screwdriver, remove the two screws.
  19. Acer TravelMate P653-V-6882 Mainboard Replacement: 19 단계, 이미지 1개 중 1개
    • Flip the laptop over so that the underside is facing up.
    • Remove the twelve 7mm Phillips #1 screws.
    • Remove the five 3mm Phillips #1 screws.
    • Disconnect the cables connecting to the WLAN module.
  20. Acer TravelMate P653-V-6882 Mainboard Replacement: 20 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 Mainboard Replacement: 20 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 Mainboard Replacement: 20 단계, 이미지 3개 중 3개
    • Locate the small gaps between the upper cover and lower case on the left and right side of the laptop.
    • Insert the opening tool into each gap to separate the one from the other.
    • Once the upper cover is separated, lift it from the lower case.
    • Be careful not to damage the upper and lower case while removing.
  21. Acer TravelMate P653-V-6882 Mainboard Replacement: 21 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 Mainboard Replacement: 21 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 Mainboard Replacement: 21 단계, 이미지 3개 중 3개
    • Detach the transparent tape securing the LCD cable.
    • Disconnect the LCD cable from the mainboard.
    • Be careful not to damage the LCD cable connector.
  22. Acer TravelMate P653-V-6882 Mainboard Replacement: 22 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 Mainboard Replacement: 22 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 Mainboard Replacement: 22 단계, 이미지 3개 중 3개
    • Detach the black tape covering the microphone cable.
    • Disconnect the microphone cable from the mainboard.
  23. Acer TravelMate P653-V-6882 Mainboard Replacement: 23 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 Mainboard Replacement: 23 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 Mainboard Replacement: 23 단계, 이미지 3개 중 3개
    • Open the USB board cable's connector latches.
    • Be careful not to damage the connectors.
  24. Acer TravelMate P653-V-6882 Mainboard Replacement: 24 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 Mainboard Replacement: 24 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 Mainboard Replacement: 24 단계, 이미지 3개 중 3개
    • Disconnect the left speaker cable from the mainboard.
  25. Acer TravelMate P653-V-6882 Mainboard Replacement: 25 단계, 이미지 1개 중 1개
    • Remove the one 7mm Phillips #1 screw.
  26. Acer TravelMate P653-V-6882 Mainboard Replacement: 26 단계, 이미지 2개 중 1개 Acer TravelMate P653-V-6882 Mainboard Replacement: 26 단계, 이미지 2개 중 2개
    • Lift the mainboard at an angle and gently turn it on its side.
    • Disconnect the LAN cable from the mainboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Daniel Popovic
회원 가입일: 01/13/20
991 평판
안내서 7개를 작성함
York University, Team S1-G6, Woodhouse Winter 2020 York University, Team S1-G6, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G6
3 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 777
