주요 콘텐츠로 건너뛰기
Acer TravelMate P653-V-6882 RAM Replacement
필요한 것
  1. Acer TravelMate P653-V-6882 RAM Replacement, Battery Pack: 1 단계, 이미지 2개 중 1개 Acer TravelMate P653-V-6882 RAM Replacement, Battery Pack: 1 단계, 이미지 2개 중 2개
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Acer TravelMate P653-V-6882 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Acer TravelMate P653-V-6882 RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the battery up.
    • Pull out the battery.
  4. Acer TravelMate P653-V-6882 RAM Replacement, Base Door: 4 단계, 이미지 1개 중 1개
    • Remove the five 7mm Phillips #1 screws.
  5. Acer TravelMate P653-V-6882 RAM Replacement: 5 단계, 이미지 1개 중 1개
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  6. Acer TravelMate P653-V-6882 RAM Replacement: 6 단계, 이미지 2개 중 1개 Acer TravelMate P653-V-6882 RAM Replacement: 6 단계, 이미지 2개 중 2개
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
  7. Acer TravelMate P653-V-6882 RAM Replacement, RAM: 7 단계, 이미지 1개 중 1개
    • Locate the two RAM sticks on the bottom of the laptop.
  8. Acer TravelMate P653-V-6882 RAM Replacement: 8 단계, 이미지 3개 중 1개 Acer TravelMate P653-V-6882 RAM Replacement: 8 단계, 이미지 3개 중 2개 Acer TravelMate P653-V-6882 RAM Replacement: 8 단계, 이미지 3개 중 3개
    • Pinch the two metal pieces holding the RAM sticks in place outwards.
    • Holding the sides of the RAM, slide the RAM sticks out.
    • Be careful not to touch the gold connection pins on the RAM sticks, as this could damage the RAM
결론
작성자
3다른 기여자 명과 함께
Basel Kandil
회원 가입일: 01/18/20
85 평판
안내서 1개를 작성함
York University, Team S1-G6, Woodhouse Winter 2020 York University, Team S1-G6, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G6
3 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 407
