주요 콘텐츠로 건너뛰기
Acer TravelMate TMB115-M-C99B Motherboard Replacement
필요한 것
  1. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer TravelMate TMB115-M-C99B Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Acer TravelMate TMB115-M-C99B Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Acer TravelMate TMB115-M-C99B Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the thirteen 6mm Phillips screws using the #0 screwdriver.
    • Remove the back of the laptop.
  3. Acer TravelMate TMB115-M-C99B Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two 7mm Phillips screws from the battery using the #0 screwdriver.
  4. Acer TravelMate TMB115-M-C99B Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Acer TravelMate TMB115-M-C99B Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Unplug the battery from the motherboard.
  5. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: 5 단계, 이미지 3개 중 1개 Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: 5 단계, 이미지 3개 중 2개 Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: 5 단계, 이미지 3개 중 3개
    • Carefully disconnect the hard drive from the motherboard.
  6. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Disconnect the two wires from the Wi-Fi interface.
  7. Acer TravelMate TMB115-M-C99B Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Acer TravelMate TMB115-M-C99B Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Remove one 6mm Phillips screw from the Wi-Fi interface using the #0 screwdriver.
  8. Acer TravelMate TMB115-M-C99B Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the Wi-Fi interface from the motherboard.
  9. Acer TravelMate TMB115-M-C99B Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Acer TravelMate TMB115-M-C99B Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the eight 7mm Phillips screws from the motherboard using the #0 screwdriver.
  10. Acer TravelMate TMB115-M-C99B Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Acer TravelMate TMB115-M-C99B Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Melissa Martinez
회원 가입일: 01/24/19
279 평판
안내서 2개를 작성함
Cal Poly, Team S1-G5, White Winter 2019 Cal Poly, Team S1-G5, White Winter 2019 회원
CPSU-WHITE-W19S1G5
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 13
전체 시간: 753
