주요 콘텐츠로 건너뛰기
Acer Travelmate 220 Disc Drive Replacement
필요한 것
  1. Acer Travelmate 220 Disc Drive Replacement, Disc Drive: 1 단계, 이미지 1/1
    • Flip your computer over so the bottom case is facing you.
  2. Acer Travelmate 220 Disc Drive Replacement: 2 단계, 이미지 1/1
    • Locate the sliding unlock button near the AC power input.
  3. Acer Travelmate 220 Disc Drive Replacement: 3 단계, 이미지 1/1
    • Slide the button in the direction of unlock and hold.
  4. Acer Travelmate 220 Disc Drive Replacement: 4 단계, 이미지 1/1
    • Gently pull the disk drive out.
  5. Acer Travelmate 220 Disc Drive Replacement: 5 단계, 이미지 1/3 Acer Travelmate 220 Disc Drive Replacement: 5 단계, 이미지 2/3 Acer Travelmate 220 Disc Drive Replacement: 5 단계, 이미지 3/3
    • Remove the four screws from the sides of the black plastic using a Phillips #00 screwdriver.
  6. Acer Travelmate 220 Disc Drive Replacement: 6 단계, 이미지 1/2 Acer Travelmate 220 Disc Drive Replacement: 6 단계, 이미지 2/2
    • Remove the black plastic that covers the metal.
  7. Acer Travelmate 220 Disc Drive Replacement: 7 단계, 이미지 1/1
    • Locate the green chip on the back of the drive.
  8. Acer Travelmate 220 Disc Drive Replacement: 8 단계, 이미지 1/2 Acer Travelmate 220 Disc Drive Replacement: 8 단계, 이미지 2/2
    • Remove the two screws securing the green chip.
  9. Acer Travelmate 220 Disc Drive Replacement: 9 단계, 이미지 1/1
    • Firmly pull off the green chip.
  10. Acer Travelmate 220 Disc Drive Replacement: 10 단계, 이미지 1/1
    • Insert the green chip in the new disk drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Justin
회원 가입일: 10/04/11
62 평판
안내서 1개 작성함
UW Stout, Team 5-5, Zhou Fall 2011 UW Stout, Team 5-5, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S5G5
3 회원들
안내서 2개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 11
30일 전: 21
전체 시간: 4,593
