주요 콘텐츠로 건너뛰기
Acoustic Guitar Bridge Replacement
필요한 것
  1. Acoustic Guitar Bridge Replacement, Bridge: 1 단계, 이미지 1/2 Acoustic Guitar Bridge Replacement, Bridge: 1 단계, 이미지 2/2
    • Remove the guitar strings.
    • Use a paper towel to remove any dust and debris from the neck of the guitar.
  2. Acoustic Guitar Bridge Replacement: 2 단계, 이미지 1/1
    • Apply a warm heating pad to the bridge to loosen the glue.
  3. Acoustic Guitar Bridge Replacement: 3 단계, 이미지 1/1
    • Carefully remove the bridge of the guitar with a putty knife or something with a thin dull blade.
    • Be careful to not scratch the finish of the guitar.
  4. Acoustic Guitar Bridge Replacement: 4 단계, 이미지 1/1
    • Carefully remove any excess glue or debris on the body of the guitar from the old bridge.
  5. Acoustic Guitar Bridge Replacement: 5 단계, 이미지 1/1
    • Apply wood glue to the new bridge and attach it to where the old one used to be.
  6. Acoustic Guitar Bridge Replacement: 6 단계, 이미지 1/1
    • Use a C-clamp to gently clamp the bridge to the body of the guitar.
  7. Acoustic Guitar Bridge Replacement: 7 단계, 이미지 1/1
    • Wait and let the glue dry.
    • Time will very based on what glue you use, but to be safe, let it sit for at least 12 hours.
  8. Acoustic Guitar Bridge Replacement: 8 단계, 이미지 1/1
    • Remove the clamp after glue has dried.
  9. Acoustic Guitar Bridge Replacement: 9 단계, 이미지 1/1
    • Restring the guitar.
  10. Acoustic Guitar Bridge Replacement: 10 단계, 이미지 1/1
    • Play!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Mitchell McCaskill
회원 가입일: 09/17/20
211 평판
안내서 1개 작성함
University of Memphis, Team S1-G12, Bishop Fall 2020 University of Memphis, Team S1-G12, Bishop Fall 2020 회원
UM-BISHOP-F20S1G12
1 회원
안내서 1개 작성하였습니다
댓글 한 개
This is a good guide Mitchell. I would encourage anyone attempting this type of a job to go watch some of the videos on YouTube by Mr. Ted Woodford. He goes into great detail about the various pitfalls of removing bridges, they aren't always as simple. Personally I don't think this repair is something to be classified as 'easy' as well. Different guitars can have very very tough adhesive bonds. I had to remove a Taylor bridge once that was a bear to get off and ensure that it went back on cleanly. The bridge can also warp and deform once it comes free of the top, so it's a good idea to clamp the bridge to a known flat surface. I appreciate the steps you outlined here though.
https://youtu.be/lsFBqPsB7VE
Ryan Field - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 64
전체 시간: 2,620
