주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acrylic Nail Tip Replacement
조회수: 1천
통계 보기:
지난 24시간
2
지난 7일:
9
지난 30일:
56
전체 시간:
1,022
댓글: 0
해당 안내서에 댓글을 남긴 사람이 없습니다. 첫 번째가 되시겠습니까?
Go to guide comments
완료함: 1
1명이 이 안내서를 "완료"로 표시했습니다. 다음은 귀하의 차례입니까?
즐겨찾기: 1
1명이 이 가이드를 즐겨찾기 (및 구독) 했습니다 — 귀하를 포함해서요!
소요 시간: 45 분
난이도: 조정
Hitting an acrylic nail on an object often comes with pain, and the full process of applying acrylic nails can take hours. Thankfully, there is no need to go to a nail shop or start the full process of applying nails over. This guide demonstrates how to repair a broken nail in a timely manner.
If you are sensitive to strong odors, opening a window, using a fan, or wearing a mask may be helpful; liquid monomer odor is extremely strong. Having a glass bowl with a lid also helps reduce odor.
Before starting, make sure you have all of the tools prepared, as the process requires you to move quickly. Step 6 requires you to collect the acrylic powder onto the brush after dipping it in the liquid monomer. From there, you have to quickly place the acrylic onto the nail and smooth it out before it hardens too much for you to maneuver and shape it.
    1. Acrylic Nail Tip Replacement, Acrylic Nail Tip: 1 단계, 이미지 1개 중 1개
      • File the nail in a back-and-forth motion with the nail file on the accessible part of the natural nail until it is no longer smooth.
      • Try not to file the acrylic nail that is is still attached to your natural nail, as it will not fit the part that broke.
      댓글 쓰기
    2. Acrylic Nail Tip Replacement: 2 단계, 이미지 1개 중 1개
      • Carefully place a drop of nail glue on the natural nail and let the glue sit for about 5 seconds.
      • Do not use more than 1-2 drops of nail glue.
      댓글 쓰기
    3. Acrylic Nail Tip Replacement: 3 단계, 이미지 2개 중 1개 Acrylic Nail Tip Replacement: 3 단계, 이미지 2개 중 2개
      • Place a nail tip in its original position and hold it in place for about 20 seconds, or until it is fully dry.
      댓글 쓰기
    4. Acrylic Nail Tip Replacement: 4 단계, 이미지 2개 중 1개 Acrylic Nail Tip Replacement: 4 단계, 이미지 2개 중 2개
      • Pour 30 milliliters of monomer in a small glass bowl.
      • Liquid nail monomer has a strong odor and is highly flammable.
      • Do not reuse the glass bowl for any food products because of possible chemical residue.
      댓글 쓰기
    5. Acrylic Nail Tip Replacement: 5 단계, 이미지 3개 중 1개 Acrylic Nail Tip Replacement: 5 단계, 이미지 3개 중 2개 Acrylic Nail Tip Replacement: 5 단계, 이미지 3개 중 3개
      • Dip the brush in the monomer and lightly tap it on the paper towel to remove the excess.
      댓글 쓰기
    6. Acrylic Nail Tip Replacement: 6 단계, 이미지 2개 중 1개 Acrylic Nail Tip Replacement: 6 단계, 이미지 2개 중 2개
      • Place the tip of the brush in clear acrylic powder at about an 80-degree angle; collect it on one side of the brush.
      댓글 쓰기
    7. Acrylic Nail Tip Replacement: 7 단계, 이미지 3개 중 1개 Acrylic Nail Tip Replacement: 7 단계, 이미지 3개 중 2개 Acrylic Nail Tip Replacement: 7 단계, 이미지 3개 중 3개
      • Apply the acrylic powder to the nail, and in a dabbing, downward motion, smooth the acrylic over the nail from top to bottom.
      댓글 쓰기
    8. Acrylic Nail Tip Replacement: 8 단계, 이미지 1개 중 1개
      • Place the nail under the UV/LED lamp until hard and firm.
      댓글 쓰기
    9. Acrylic Nail Tip Replacement: 9 단계, 이미지 3개 중 1개 Acrylic Nail Tip Replacement: 9 단계, 이미지 3개 중 2개 Acrylic Nail Tip Replacement: 9 단계, 이미지 3개 중 3개
      • Use a nail drill to file the nail to achieve an even acrylic coat by drilling in a side-to-side motion, working your way from top to bottom.
      • Use a speed of 7-9 on the nail drill.
      • If you do not have a nail drill, you can also use a nail file.
      댓글 쓰기
    10. Acrylic Nail Tip Replacement: 10 단계, 이미지 3개 중 1개 Acrylic Nail Tip Replacement: 10 단계, 이미지 3개 중 2개 Acrylic Nail Tip Replacement: 10 단계, 이미지 3개 중 3개
      • Buff the nail until it is smooth, and use a paper towel to wipe off excess powder.
      댓글 쓰기
    11. Acrylic Nail Tip Replacement: 11 단계, 이미지 3개 중 1개 Acrylic Nail Tip Replacement: 11 단계, 이미지 3개 중 2개 Acrylic Nail Tip Replacement: 11 단계, 이미지 3개 중 3개
      • Optional: coat the nail with clear polish.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자
Alysia Williams
회원 가입일: 02/28/22
222 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 56
전체 시간: 1,022
