주요 콘텐츠로 건너뛰기
AcuRite 02032 Wind Cup Assembly Replacement
필요한 것
  1. AcuRite 02032 Wind Cup Assembly Replacement, Battery: 1 단계, 이미지 1/3 AcuRite 02032 Wind Cup Assembly Replacement, Battery: 1 단계, 이미지 2/3 AcuRite 02032 Wind Cup Assembly Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the battery compartment lid by lifting upward.
  2. AcuRite 02032 Wind Cup Assembly Replacement: 2 단계, 이미지 1/1
    • Pull the ribbon to eject the 2 X AA alkaline batteries.
  3. AcuRite 02032 Wind Cup Assembly Replacement: 3 단계, 이미지 1/3 AcuRite 02032 Wind Cup Assembly Replacement: 3 단계, 이미지 2/3 AcuRite 02032 Wind Cup Assembly Replacement: 3 단계, 이미지 3/3
    • Once the batteries are removed, it is safe to proceed.
  4. AcuRite 02032 Wind Cup Assembly Replacement, Base: 4 단계, 이미지 1/1
    • Remove the four 0.8cm screws that attach the bottom panel to the device
    • An extended driver is needed to reach 3 of these screws. If you are using the 64 - bit driver kit you can extend the driver by inserting the driver PH1, (Phillips size 1) into the size 4 hexagonal adapter.
  5. AcuRite 02032 Wind Cup Assembly Replacement: 5 단계, 이미지 1/2 AcuRite 02032 Wind Cup Assembly Replacement: 5 단계, 이미지 2/2
    • Gently lift the top section of the weather center away from the base. With all the screws removed it should lift off easily.
  6. AcuRite 02032 Wind Cup Assembly Replacement, Wind Cup Assembly: 6 단계, 이미지 1/1
    • Remove the four 0.8cm screws inside the case located near the fan using the J1 screw bit.
  7. AcuRite 02032 Wind Cup Assembly Replacement: 7 단계, 이미지 1/2 AcuRite 02032 Wind Cup Assembly Replacement: 7 단계, 이미지 2/2
    • With all four screws removed, the wind cup assembly should lift straight up off the middle section.
    • Set down the bottom half of the weather center careful. There are two small pegs that will break with the slightest amount of pressure.
  8. AcuRite 02032 Wind Cup Assembly Replacement: 8 단계, 이미지 1/1
    • Replace the old wind cup assembly with the new assembly that was purchased.
결론
Ben Kegel
회원 가입일: 09/15/16
350 평판
안내서 3개 작성하였습니다
CSU Fullerton, Team 1-4, Bruce Fall 2016 CSU Fullerton, Team 1-4, Bruce Fall 2016 회원
CSUF-BRUCE-F16S1G4
5 회원들
안내서 7개 작성하였습니다
댓글 3개
Do you have to replace the whole top, wind cups,top plate with solar panel, just for the wind cups?
Tom Halverson - 답글
For a broken wind cups do you have to replace the top section with the solar panel?
Tom Halverson - 답글
No. After you take it apart hold the shaft turn broken cup assy off. Install new cups in reverse order.
Larry Lindsay - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 1,579
