주요 콘텐츠로 건너뛰기
AcuRite 02032 Wind Vane Replacement
필요한 것
  1. AcuRite 02032 Wind Vane Replacement, Battery: 1 단계, 이미지 1/3 AcuRite 02032 Wind Vane Replacement, Battery: 1 단계, 이미지 2/3 AcuRite 02032 Wind Vane Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the battery compartment lid by lifting upward.
  2. AcuRite 02032 Wind Vane Replacement: 2 단계, 이미지 1/1
    • Pull the ribbon to eject the 2 X AA alkaline batteries.
  3. AcuRite 02032 Wind Vane Replacement: 3 단계, 이미지 1/3 AcuRite 02032 Wind Vane Replacement: 3 단계, 이미지 2/3 AcuRite 02032 Wind Vane Replacement: 3 단계, 이미지 3/3
    • Once the batteries are removed, it is safe to proceed.
  4. AcuRite 02032 Wind Vane Replacement, Wind Vane: 4 단계, 이미지 1/3 AcuRite 02032 Wind Vane Replacement, Wind Vane: 4 단계, 이미지 2/3 AcuRite 02032 Wind Vane Replacement, Wind Vane: 4 단계, 이미지 3/3
    • Firmly grasp the windvane with one hand and the rest of the device with the other hand.
    • Pull straight outwards. A quick yank with force should be enough to remove the propeller.
  5. AcuRite 02032 Wind Vane Replacement: 5 단계, 이미지 1/2 AcuRite 02032 Wind Vane Replacement: 5 단계, 이미지 2/2
    • To reattach the replacement wind vane, line up the small notch in the socket where the pieces fit together then carefully push the parts together.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ben Kegel
회원 가입일: 09/15/16
350 평판
안내서 3개 작성하였습니다
CSU Fullerton, Team 1-4, Bruce Fall 2016 CSU Fullerton, Team 1-4, Bruce Fall 2016 회원
CSUF-BRUCE-F16S1G4
5 회원들
안내서 7개 작성하였습니다
댓글 한 개
I had a herd of elk come through my yard (judging by the large hoofprints). Apparently one of them got tangled up in the guy rope for my antenna mast and the mast came tumbling to the ground. At the top of the mast about 35 feet up was my Acurite 5-in-1 Sensor, which also fell to the ground and broke the wind vane. The replacement vane cost 5 dollars. Pull off the broken one, push on the new one, done in a few seconds.
Acurite’s instructions about replacing the wind vane are as follows:
“The wind vane is pressed onto the shaft, pull firmly to remove it. To attach the wind vane, align the wind vane with the flat on the shaft and press into place.”
They don’t say anything about removing the batteries.
Hal Jordan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 22
전체 시간: 1,295
