소개
How to open a Asus N73J laptop and install a SSD or HDD in the free HDD bay.
필요한 것
Use a small flathead screwdriver or the flat end of a spudger to gently push down the five pins just above the top row of keys that secure the keyboard to the laptop.
Remove these seven screws with a JIS #1 (or PH 1) to unlock the back cover.
Here you can see the slot for an extra RAM module.
When finished close the laptop and turn it over.
Open the back cover to get access to:
the HDD-bays
the RAM modules
the WiFI module
If you haven't done so already now is the time to mount your SSD or HDD in the caddy.
Gently slide your new SSD/HDD in the empty HDD bay. And do not forget to secure it to the body of the laptop with a few screws.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 3개
Great help with the pics. Thank you so much
