주요 콘텐츠로 건너뛰기
Adjust Goose-neck (adjustable quill stem) on Specialized Expedition
필요한 것
  1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 1 단계, 이미지 1/2 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 1 단계, 이미지 2/2
    • Remove the bolt cover with a flathead screwdriver.
  2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 2 단계, 이미지 1/3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 2 단계, 이미지 2/3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 2 단계, 이미지 3/3
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  3. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 3 단계, 이미지 1/3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 3 단계, 이미지 2/3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 3 단계, 이미지 3/3
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
aaron thielk
회원 가입일: 10/10/10
1,882 평판
안내서 5개 작성하였습니다
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 회원
CPSU-MANESS-F10S5G13
4 회원들
안내서 17개 작성하였습니다
댓글 한 개
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 9,221
