주요 콘텐츠로 건너뛰기
Adjust the Action (String Height) on Ibanez SR405QM
필요한 것
  1. Adjust the Action (String Height) on Ibanez SR405QM, Adjust the Action (String Height) on Ibanez SR405QM: 1 단계, 이미지 1/2 Adjust the Action (String Height) on Ibanez SR405QM, Adjust the Action (String Height) on Ibanez SR405QM: 1 단계, 이미지 2/2
    • Pay attention to the distance between both the fretboard and pickups.
    • Test the strings by plucking and take note of which ones are difficult to play or are producing an unpleasant metallic sound.
  2. Adjust the Action (String Height) on Ibanez SR405QM: 2 단계, 이미지 1/2 Adjust the Action (String Height) on Ibanez SR405QM: 2 단계, 이미지 2/2
    • Using a 2 mm Allen Key turn the corresponding string's screw clockwise to raise the string and counterclockwise to lower the string.
    • The screw is located on the bridge of the guitar next to its corresponding string.
    • While modifying a strings height try plucking the string and listening to the sound produced until at desired sound.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Chris Pittner
회원 가입일: 01/11/13
220 평판
안내서 7개 작성하였습니다
Cal Poly, Team 5-18, Forte Winter 2013 Cal Poly, Team 5-18, Forte Winter 2013 회원
CPSU-FORTE-W13S5G18
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 24
30일 전: 100
전체 시간: 6,206
