주요 콘텐츠로 건너뛰기
Adjust turntable speed
필요한 것
  1. Adjust turntable speed, Adjust turntable speed: 1 단계, 이미지 2개 중 1개 Adjust turntable speed, Adjust turntable speed: 1 단계, 이미지 2개 중 2개
    • First method is to put a pattern disc on the table such as the shown one. There are also print templates on the web.
    • These patterns on the disc interact with light. Except it doesn't work with most led lights. So you need an old fashion glowing filament or fluorescent lamp because they are flickering with our power line frequnecy.
    • On the patterned disc you see two main areas with thicker lines. The inner three pattern circles are for 60 Hz e.g. north america and the outer patterns are for 50Hz.
    • The 3 pattern circles itself representing 3 different speeds. 33 1/3, 45 and 78 rpm. The stroboscopic effect occurs if the flickering light is directed to the pattern disc and the corresponding speed of the table makes the patter look as it stands still. So the pattern in the corresponding circle isn't moving, if the speed setup is right.
  2. Adjust turntable speed: 2 단계, 이미지 2개 중 1개 Adjust turntable speed: 2 단계, 이미지 2개 중 2개
    • By adjusting two screews on the bottom side of the turntable you can affect the motor speed and thus bring the pattern to stop. Here a DUAL player is shown who has direct access to two motor screws. One for 33 1/3 rpm and one for 45 rpm.
  3. Adjust turntable speed: 3 단계, 이미지 2개 중 1개 Adjust turntable speed: 3 단계, 이미지 2개 중 2개
    • On this more sopisticated technics player are marks on the table and a red light.
    • With the marked wheel you can adjust the speed very easy.
결론
This is the way to easily improve your turntable sound.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Christian
회원 가입일: 09/04/20
1,252 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 54
지난 30일: 166
전체 시간: 491
