주요 콘텐츠로 건너뛰기
Adjusting Contrast on TI-Nspire Calculator
  1. Adjusting Contrast on TI-Nspire Calculator, Adjusting Contrast on TI-Nspire Calculator: 1 단계, 이미지 1/2 Adjusting Contrast on TI-Nspire Calculator, Adjusting Contrast on TI-Nspire Calculator: 1 단계, 이미지 2/2
    • Remove the front protective cover by sliding it off of the calculator.
    • Press the "ON" button to turn on the calculator.
  2. Adjusting Contrast on TI-Nspire Calculator: 2 단계, 이미지 1/3 Adjusting Contrast on TI-Nspire Calculator: 2 단계, 이미지 2/3 Adjusting Contrast on TI-Nspire Calculator: 2 단계, 이미지 3/3
    • Press the "2ND" button at the top left portion of the keypad. An arrow pointing up will appear at the top left corner of the screen.
    • Press and hold the "UP" arrow until you have increased the contrast to a level that is easily visible for yourself. A common level to set the contrast is 5.
    • To decrease the contrast, press the "2ND" button, then press and hold the "DOWN" arrow.
결론
Now you should have the image contrast set to your preferences.
다른 한 분이 해당 안내서를 완성하였습니다.
Alan Wong
회원 가입일: 09/26/12
63 평판
안내서 1개 작성함
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 회원
CPSU-FORTE-F12S7G52
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 5,937
