주요 콘텐츠로 건너뛰기
Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet
  1. Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet, Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet: 1 단계, 이미지 1/1
    • Before starting the repair, make sure that the device is unplugged and the water reservoir is empty.
    • Detach the water reservoir from the brewer by lifting the reservoir vertically from the device.
  2. Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet: 2 단계, 이미지 1/2 Adjusting Keurig K75 Platinum Brewing System Reservoir Magnet: 2 단계, 이미지 2/2
    • The magnet is located in the bottom of the reservoir.
    • Remove the grey lid from the top of the reservoir.
    • Insert your hand and manually realign the magnet to where it slides freely in its enclosed area.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alexander Vo
회원 가입일: 01/11/13
94 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-2, Maness Winter 2013 Cal Poly, Team 20-2, Maness Winter 2013 회원
CPSU-MANESS-W13S20G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 50
전체 시간: 19,886
