주요 콘텐츠로 건너뛰기
Adjusting Nishiki Aero II Front Derailleur
필요한 것
  1. Adjusting Nishiki Aero II Front Derailleur, Adjusting Nishiki Aero II Front Derailleur: 1 단계, 이미지 1개 중 1개
    • Shift the bike's rear derailleur onto the innermost gear.
  2. Adjusting Nishiki Aero II Front Derailleur: 2 단계, 이미지 1개 중 1개
    • Shift the front derailleur as far inward as it can go.
    • If the chain falls off, tighten the outside limit screw on top of the derailleur.
    • If the chain can't shift to the lower gear, loosen the outside limit screw on top of the derailleur.
    • Yes, the outer limit screw adjusts the inner derailleur limit.
  3. Adjusting Nishiki Aero II Front Derailleur: 3 단계, 이미지 1개 중 1개
    • Next, shift the rear derailleur onto the outermost gear.
  4. Adjusting Nishiki Aero II Front Derailleur: 4 단계, 이미지 1개 중 1개
    • Shift the front derailleur as far outwards as you can.
    • If the derailleur shifts the chain off the gear, tighten the inner limit screw on top of the front derailleur.
    • If the derailleur is unable to shift onto the outer gear, loosen the inner limit screw on top of the front derailleur.
    • Just like last time, the inner limit screw adjusts the outer limit of the derailleur.
결론
Now, your bike shouldn't have any more problems with the chain falling off.
작성자
2다른 기여자 명과 함께
Tobias Elder
회원 가입일: 04/25/13
113 평판
안내서 7개를 작성함
Cal Poly, Team 21-53, Johann Spring 2013 Cal Poly, Team 21-53, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G53
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 1,883
