주요 콘텐츠로 건너뛰기
Adjusting Nishiki Aero II Seat
필요한 것
  1. Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: 1 단계, 이미지 3개 중 1개 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: 1 단계, 이미지 3개 중 2개 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: 1 단계, 이미지 3개 중 3개
    • Loosen the bolt that secures your seat.
    • To do so, use one wrench to hold the larger nut on the left side of the bike still while you loosen the nut on the right.
  2. Adjusting Nishiki Aero II Seat: 2 단계, 이미지 2개 중 1개 Adjusting Nishiki Aero II Seat: 2 단계, 이미지 2개 중 2개
    • Now that it can move, move the seat by wiggling it and pulling it in the direction you want to adjust it.
    • You want to the adjust the seat so that, when a pedal is at the far end of its rotation, your leg is fully extended.
    • Don't worry about getting it perfect on the first try. Instead, guess your adjustment, tighten the bolt a little bit, try it out, and adjust again until you get it right.
  3. Adjusting Nishiki Aero II Seat: 3 단계, 이미지 1개 중 1개
    • Once your seat is at the desired height, you just tighten the bolt the same way you loosened it.
    • Use two wrenches, one to hold it still and the other to tighten the nut.
    • Make sure it's very tight, or else the seat might twist or lower over time.
결론
작성자
2다른 기여자 명과 함께
Tobias Elder
회원 가입일: 04/25/13
113 평판
안내서 7개를 작성함
Cal Poly, Team 21-53, Johann Spring 2013 Cal Poly, Team 21-53, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G53
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 12
전체 시간: 2,980
