주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Adjusting Singer Brilliance 6180
필요한 것
  1. Adjusting Singer Brilliance 6180, Needle Position: 1 단계, 이미지 2개 중 1개 Adjusting Singer Brilliance 6180, Needle Position: 1 단계, 이미지 2개 중 2개
    • If the position of the needle is not correct, some errors will occur, which can make the user very annoyed.
    • The exact position of the needle is extremely important on a sewing machine. The looper needs to pass the needle in a very small distance to pull out the thread, if this does not work exactly, there will be many errors such as loops, broken needles, broken threads and banging noises,
    • The two photos show the correct position of the needle in the needle plate. It must be exactly in the middle of the hole plate on the side and in the sewing direction. (If the needle plate is not shifted.)
  2. Adjusting Singer Brilliance 6180, Remove left cover: 2 단계, 이미지 3개 중 1개 Adjusting Singer Brilliance 6180, Remove left cover: 2 단계, 이미지 3개 중 2개 Adjusting Singer Brilliance 6180, Remove left cover: 2 단계, 이미지 3개 중 3개
    • To access the adjustment plate and screw, you need to remove the left cover.
    • Loosen the Phillips screw # 2 on the back a little, it must not be removed.
    • Remove the Phillips # 2 screw on the left side.
    • Pull the cover towards the left to remove it.
  3. Adjusting Singer Brilliance 6180, Method 1: Adjusting the needle carrier: 3 단계, 이미지 3개 중 1개 Adjusting Singer Brilliance 6180, Method 1: Adjusting the needle carrier: 3 단계, 이미지 3개 중 2개 Adjusting Singer Brilliance 6180, Method 1: Adjusting the needle carrier: 3 단계, 이미지 3개 중 3개
    • The needle carrier is attached at the top with a 2 mm Allen screw. Loosen the screw to slightly move the cantilever. It's pretty tight the first time, be careful.
    • To move the needle carrier, tap very lightly, e.g. with the handle of a screwdriver, on the axis of the needle carrier.
    • If you tap the front of the axle, the needle moves towards you, the distance between the needle and the looper increases.
    • If you tap on the back of the axle, the needle will move away from you and the distance between the needle and the looper will decrease.
    • Lower the needle all the way down. You should just be able to slip a piece of paper between the needle and the looper tip. (Picture 3). The needle must be able to slide easily to the left and right when zigzagging.
    • Tighten the Allen screw again.
    • Check that the machine sews cleanly again, especially with zigzag stitches. If all is well, check the lateral displacement and go straight to step 8.
  4. Adjusting Singer Brilliance 6180, Method 2: Adjusting the Needle Carrier: 4 단계, 이미지 3개 중 1개 Adjusting Singer Brilliance 6180, Method 2: Adjusting the Needle Carrier: 4 단계, 이미지 3개 중 2개 Adjusting Singer Brilliance 6180, Method 2: Adjusting the Needle Carrier: 4 단계, 이미지 3개 중 3개
    • The cantilever slides past a plate. You can adjust the position of the needle by slightly bending this plate.
    • The setting plate is marked yellow in the first picture. It has to be taken out and bent very slightly.
    • First unscrew the rod for the thread run with a flat screwdriver.
    • The adjustment plate is now accessible.
  5. Adjusting Singer Brilliance 6180: 5 단계, 이미지 2개 중 1개 Adjusting Singer Brilliance 6180: 5 단계, 이미지 2개 중 2개
    • The adjustment plate is fixed with a Phillips screw. Gently twist it out.
    • Use a well-fitting Phillips screwdriver and press firmly as you unscrew. The screw is quite tight and the screw head must not be damaged under any circumstances.
  6. Adjusting Singer Brilliance 6180: 6 단계, 이미지 1개 중 1개
    • Push the needle carrier a little forward from behind to relieve the adjustment plate, then simply lift it up using a pair of tweezers.
  7. Adjusting Singer Brilliance 6180: 7 단계, 이미지 2개 중 1개 Adjusting Singer Brilliance 6180: 7 단계, 이미지 2개 중 2개
    • This is what the setting plate looks like. It regulates the position in sewing direction.
    • To adjust, you have to bend the lower part of the plate slightly outwards. Use two pliers to do this.
    • The bending is really minimal. You may have to remove the plate again if the needle isn't yet in the right position.
    • Reinstall the plate and check the position of the needle in sewing direction.
    • When you fasten the screw, the plate - and with it the needle - must remain movable to the side, otherwise there will be no zigzag stitch, etc. Grease the sliding surfaces. You may have to take it out again and bend it back very slightly.
  8. Adjusting Singer Brilliance 6180, Adjust lateral shift: 8 단계, 이미지 2개 중 1개 Adjusting Singer Brilliance 6180, Adjust lateral shift: 8 단계, 이미지 2개 중 2개
    • The lateral position of the needle is easier to adjust. A black banjo bolt is used for this purpose. This position is set at the factory and does not normally need to be readjusted.
    • The hollow screw is secured from the factory with red color. You may have to remove it. To get to the screw better, you can unhook the transverse return spring.
    • Adjust the screw using a 1.4 mm Allen key. Observe how the lateral position of the needle changes.
  9. Adjusting Singer Brilliance 6180, Tip: 9 단계, 이미지 1개 중 1개
    • One last hint: sewing starts better if you lower the needle using the handwheel into the throat plate after each switch-on; the motors adjust themselves with a brief click. Lift the needle up again and you're good to go - until the next time you turn it off.
결론
다른 11명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
VauWeh
회원 가입일: 10/19/15
307,531 평판
안내서 309개를 작성함
16가이드 댓글
Hallo Anleitung ist super. Leider näht meine Maschine seither nur noch gerade Stiche. Egal was ich einstelle….was ist schief gelaufen? Kann jmd helfen?
Sabine - 답글
Ja. Wie in den anderen Kommentaren auch schon geschrieben: das Plättchen muss seitlich verschiebbar bleiben, damit die Nadel hin und her wandern kann . Probiere es mit viel Gefühl ganz wenig zurück zu biegen. Man merkt, wie das Plättchen festgeht, wenn man die Schraube anzieht. Das darf halt nicht sein. weiße Hebel muss die Nadel verschieben können. Die Einstellung ist wirklich knifflig, es ist eine zickige Maschine…
VauWeh -
Tausend Dank für die Anleitung!!!
Ich war schon so verzweifelt und wollte mir eine neue Nähmaschine kaufen. (Hatte meine damals bei Lidl gekauft. Garantie und Gewährleistung ist längst abgelaufen und Einschicken erschien mir zu umständlich.)
Und dann das hier…
Sie läuft wieder absolut mittig, Zick-Zack ist auch kein Problem, einfach herrlich!
Viele liebe Grüße
Mare lei - 답글
Freut mich sehr, wieder ein sensibles Maschinchen gerettet. Ich habe den Verdacht, dass das passiert, wenn man während des Transports am Stoff zieht und nicht nur die Nadel verbogen wird.
VauWeh -
Guten Tag Ich habe gerade die gleiche Maschine und der Faden kommt nicht mehr hoch . der Greifer Zeitpunkt ist um 9mm nach links verschoben .Bei Bernina, Pfaff, kann man den Greifer mit einer Schraube ,hinter der Maschine lösen und so um ein Zahnrad verstellen.
Bei der Brillianz habe ich nach der Gehäuseöffnung gesehen das am Boden das weisse runde abdeckblättchen zum Greifer einsteller führt.
Mit einem 7mm SWISS-Gryp Nuss -Schraubendreher kann man diese lösen und den Greifer auf die richtige Position stellen ,danach diese Schraube wieder genug anziehen
Ich habe auch den Fehler gemacht und das ganzr Gehäuse geöffnet Gruss Paul Lehmann
paul lehmann - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 72
지난 30일: 321
전체 시간: 25,615
