소개
This guide will show the procedure for removing each segment of the pump rod. It can be used to replace the entire rod, or just to replace a single pump rod segment.
필요한 것
Grab firmly on the T-handle and lift the pump rod straight up.
Expose the first connection of the pump rod, and support the portion below the connection.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
