주요 콘텐츠로 건너뛰기
Afridev Tank Replacement
필요한 것
  1. Afridev Tank Replacement, Head: 1 단계, 이미지 2개 중 1개 Afridev Tank Replacement, Head: 1 단계, 이미지 2개 중 2개
    • Assemble the required tools, including the Afridev tool and crescent wrenches.
  2. Afridev Tank Replacement: 2 단계, 이미지 3개 중 1개 Afridev Tank Replacement: 2 단계, 이미지 3개 중 2개 Afridev Tank Replacement: 2 단계, 이미지 3개 중 3개
    • Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
  3. Afridev Tank Replacement: 3 단계, 이미지 2개 중 1개 Afridev Tank Replacement: 3 단계, 이미지 2개 중 2개
    • Loosen the bolt on front of the face plate with the Afridev tool.
    • Remove the plate from the pump by lifting it straight up.
  4. Afridev Tank Replacement, Axle and Handle: 4 단계, 이미지 3개 중 1개 Afridev Tank Replacement, Axle and Handle: 4 단계, 이미지 3개 중 2개 Afridev Tank Replacement, Axle and Handle: 4 단계, 이미지 3개 중 3개
    • Insert the T-handle into the top cylinder of the exposed pump rod.
  5. Afridev Tank Replacement: 5 단계, 이미지 2개 중 1개 Afridev Tank Replacement: 5 단계, 이미지 2개 중 2개
    • Loosen the 2 bolts on either side of handle.
    • It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
  6. Afridev Tank Replacement: 6 단계, 이미지 3개 중 1개 Afridev Tank Replacement: 6 단계, 이미지 3개 중 2개 Afridev Tank Replacement: 6 단계, 이미지 3개 중 3개
    • Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
  7. Afridev Tank Replacement: 7 단계, 이미지 2개 중 1개 Afridev Tank Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the handle to a horizontal position.
  8. Afridev Tank Replacement: 8 단계, 이미지 3개 중 1개 Afridev Tank Replacement: 8 단계, 이미지 3개 중 2개 Afridev Tank Replacement: 8 단계, 이미지 3개 중 3개
    • While one person lifts up on the T-handle, remove the bolt and connection pieces.
  9. Afridev Tank Replacement: 9 단계, 이미지 3개 중 1개 Afridev Tank Replacement: 9 단계, 이미지 3개 중 2개 Afridev Tank Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the bolt and connection pieces from the handle.
    • Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
  10. Afridev Tank Replacement: 10 단계, 이미지 2개 중 1개 Afridev Tank Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the handle from the pump.
    • Be sure to set the handle in a sanitary place to prevent contamination.
  11. Afridev Tank Replacement, Pump Rod: 11 단계, 이미지 2개 중 1개 Afridev Tank Replacement, Pump Rod: 11 단계, 이미지 2개 중 2개
    • Grab firmly on the T-handle and lift the pump rod straight up.
    • Expose the first connection of the pump rod, and support the portion below the connection.
  12. Afridev Tank Replacement: 12 단계, 이미지 2개 중 1개 Afridev Tank Replacement: 12 단계, 이미지 2개 중 2개
    • While holding the pump rod below the first connection tightly, lower the first portion of the rod to a horizontal position.
  13. Afridev Tank Replacement: 13 단계, 이미지 3개 중 1개 Afridev Tank Replacement: 13 단계, 이미지 3개 중 2개 Afridev Tank Replacement: 13 단계, 이미지 3개 중 3개
    • Unhook the first connection by pushing it out and down, then pulling it away from the rest of the rod.
  14. Afridev Tank Replacement: 14 단계, 이미지 3개 중 1개 Afridev Tank Replacement: 14 단계, 이미지 3개 중 2개 Afridev Tank Replacement: 14 단계, 이미지 3개 중 3개
    • Repeat steps 11-13 for the remaining sections of pump rod.
    • Be sure to set the pump rod segments above the ground to avoid contamination.
  15. Afridev Tank Replacement, Tank: 15 단계, 이미지 2개 중 1개 Afridev Tank Replacement, Tank: 15 단계, 이미지 2개 중 2개
    • Place one wrench on the top side of the top base of the tank spout.
    • Place another wrench on the underside of the bolt in order to get more leverage.
    • Pull the top wrench to the right, and the bottom wrench to the left.
  16. Afridev Tank Replacement: 16 단계, 이미지 3개 중 1개 Afridev Tank Replacement: 16 단계, 이미지 3개 중 2개 Afridev Tank Replacement: 16 단계, 이미지 3개 중 3개
    • Remove the loosened bolt from the pump.
    • Repeat this procedure for the 3 remaining bolts.
  17. Afridev Tank Replacement: 17 단계, 이미지 2개 중 1개 Afridev Tank Replacement: 17 단계, 이미지 2개 중 2개
    • Lift the tank straight up to remove it from the pump.
    • Be sure to place the tank in a sanitary place to prevent contamination.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jake Devincenzi
회원 가입일: 04/18/11
118,792 평판
안내서 57개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 424
