주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Afterglow Wireless PS3 Controller Button Replacement
필요한 것
  1. Afterglow Wireless PS3 Controller Button Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Button Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Button Replacement, Button: 2 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Button Replacement, Button: 2 단계, 이미지 2개 중 2개
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
  3. Afterglow Wireless PS3 Controller Button Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
  4. Afterglow Wireless PS3 Controller Button Replacement: 4 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Button Replacement: 4 단계, 이미지 2개 중 2개
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so you can access the main motherboard.
  5. Afterglow Wireless PS3 Controller Button Replacement: 5 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Button Replacement: 5 단계, 이미지 2개 중 2개
    • Pull both vibration motors straight up from their holding place.
  6. Afterglow Wireless PS3 Controller Button Replacement: 6 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Button Replacement: 6 단계, 이미지 2개 중 2개
    • Unscrew the two 9mm Phillips #0 screws holding the motherboard to the controller front plate.
  7. Afterglow Wireless PS3 Controller Button Replacement: 7 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Button Replacement: 7 단계, 이미지 2개 중 2개
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The buttons have mini-motherboards secured in place on the front plate. Carefully pull these out.
  8. Afterglow Wireless PS3 Controller Button Replacement: 8 단계, 이미지 3개 중 1개 Afterglow Wireless PS3 Controller Button Replacement: 8 단계, 이미지 3개 중 2개 Afterglow Wireless PS3 Controller Button Replacement: 8 단계, 이미지 3개 중 3개
    • Pick up the controller front plate and carefully turn it over so that the buttons left in it will fall out.
    • You may want to flip it while holding it over a container so the buttons do not go bouncing away from your work space.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Aj Coello
회원 가입일: 02/17/17
1,164 평판
안내서 6개를 작성함
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017 회원
USFT-HOFFMAN-S17S19G5
4 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 21
지난 30일: 90
전체 시간: 2,528
