주요 콘텐츠로 건너뛰기
Afterglow Wireless PS3 Controller Joystick Replacement
필요한 것
  1. Afterglow Wireless PS3 Controller Joystick  Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Joystick  Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Joystick  Replacement, Joystick: 2 단계, 이미지 1개 중 1개
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
  3. Afterglow Wireless PS3 Controller Joystick  Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
  4. Afterglow Wireless PS3 Controller Joystick  Replacement: 4 단계, 이미지 2개 중 1개 Afterglow Wireless PS3 Controller Joystick  Replacement: 4 단계, 이미지 2개 중 2개
    • Jiggle both joy stick control mini-motherboards out of their holding place.
  5. Afterglow Wireless PS3 Controller Joystick  Replacement: 5 단계, 이미지 3개 중 1개 Afterglow Wireless PS3 Controller Joystick  Replacement: 5 단계, 이미지 3개 중 2개 Afterglow Wireless PS3 Controller Joystick  Replacement: 5 단계, 이미지 3개 중 3개
    • Firmly grip the joystick housing with your forefingers by the yellow squares.
    • Use your other hand to get a grip on the black plastic joystick and pull directly away from the housing.
    • This will take some force to remove.
    • Try not to use the motherboard for leverage because it is delicate.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Aj Coello
회원 가입일: 02/17/17
1,014 평판
안내서 6개를 작성함
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017 회원
USFT-HOFFMAN-S17S19G5
4 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 41
지난 30일: 178
전체 시간: 4,217
