주요 콘텐츠로 건너뛰기
Afterglow Wireless PS3 Controller Motherboard Replacement
필요한 것
  1. Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: 1 단계, 이미지 1/2 Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: 1 단계, 이미지 2/2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Motherboard Replacement, Motherboard: 2 단계, 이미지 1/1
    • Desolder the battery connection from the motherboard.
    • Use this guide for more information on soldering.
  3. Afterglow Wireless PS3 Controller Motherboard Replacement: 3 단계, 이미지 1/2 Afterglow Wireless PS3 Controller Motherboard Replacement: 3 단계, 이미지 2/2
    • Unscrew the two 9mm Phillips #0 screws that secure the motherboard to the controller front plate.
  4. Afterglow Wireless PS3 Controller Motherboard Replacement: 4 단계, 이미지 1/2 Afterglow Wireless PS3 Controller Motherboard Replacement: 4 단계, 이미지 2/2
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The bottons have mini-motherboards secured in place on the front plate. Carefully pull these out.
  5. Afterglow Wireless PS3 Controller Motherboard Replacement: 5 단계, 이미지 1/2 Afterglow Wireless PS3 Controller Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove two button padding from the back of motherboard.
  6. Afterglow Wireless PS3 Controller Motherboard Replacement: 6 단계, 이미지 1/2 Afterglow Wireless PS3 Controller Motherboard Replacement: 6 단계, 이미지 2/2
    • Desolder the four button connections from the motherboard.
    • Desolder the joy stick connections located on the front.
결론
Natalie Cox
회원 가입일: 02/17/17
207 평판
안내서 2개 작성하였습니다
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017 회원
USFT-HOFFMAN-S17S19G5
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 994
