주요 콘텐츠로 건너뛰기
Aiptek Pocket DVII 1.3M LCD Memory Ejecting Assembly Replacement
필요한 것
  1. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: 1 단계, 이미지 1/3 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: 1 단계, 이미지 2/3 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: 1 단계, 이미지 3/3
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 2 단계, 이미지 1/1
    • Unscrew the three 4mm screws from the battery side of the device. Use a Phillips screw driver.
  3. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 3 단계, 이미지 1/1
    • Remove the four screws from the back side.
  4. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 4 단계, 이미지 1/2 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 4 단계, 이미지 2/2
    • Remove the sticky black dot.
    • Remove the hidden screw.
  5. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 5 단계, 이미지 1/2 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 5 단계, 이미지 2/2
    • Remove the two screws from the top side of the device.
    • Remove the two screws from the bottom side of the device.
  6. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 6 단계, 이미지 1/1
    • Remove the rear cover.
    • Be careful not to lose the spring inside.
  7. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 7 단계, 이미지 1/1
    • Pull back the front cover so that you can dislodge the side cover.
  8. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 8 단계, 이미지 1/1
    • Unfold the device and be careful not to tear the black and red power supply wires.
  9. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 9 단계, 이미지 1/1
    • Remove the four screws from the motherboard.
  10. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 10 단계, 이미지 1/1
    • Take out the motherboard while disconnecting the flip screen's cable from underneath.
  11. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 11 단계, 이미지 1/1
    • Remove the side cover.
    • Flip the device and locate the ejecting assembly.
  12. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 12 단계, 이미지 1/1
    • Remove the grey button.
  13. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 13 단계, 이미지 1/1
    • Push the metal arm the button was on all the way up.
  14. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 14 단계, 이미지 1/2 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: 14 단계, 이미지 2/2
    • Pop the main metal arm out of the other metal arm's socket.
    • Position the arm vertically like in the first picture. The arm should come off easily.
    • Replace the ejecting arm.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Gyozo Aba Hivatal
회원 가입일: 01/21/15
561 평판
안내서 5개 작성하였습니다
USF Tampa, Team 6-4, Brown Winter 2015 USF Tampa, Team 6-4, Brown Winter 2015 회원
USFT-BROWN-W15S6G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 119
