주요 콘텐츠로 건너뛰기
Aiptek Pocket DVII 1.3M LCD Display Screen Replacement
필요한 것
  1. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: 1 단계, 이미지 1/3 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: 1 단계, 이미지 2/3 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: 1 단계, 이미지 3/3
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 2 단계, 이미지 1/2 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 2 단계, 이미지 2/2
    • Remove the sticky black dots.
    • Remove the three black 4mm screws from the flip screen. Use a Phillips head screw driver.
  3. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 3 단계, 이미지 1/1
    • Using an opening tool, separate the cover from the screen.
    • The cover won't completely come off. This will happen in the next step.
    • Don't be afraid to use a little more force.
  4. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 4 단계, 이미지 1/1
    • Using an opening tool remove the outside cover of the flip screen.
    • Move the cover towards the lens and then away from the screen.
  5. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 5 단계, 이미지 1/2 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 5 단계, 이미지 2/2
    • With the cover off, push the brown locking mechanism up, so the picture cable can be remove.
    • You only need to unplug the bottom cable in the picture.
  6. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 6 단계, 이미지 1/1
    • Remove the two black screws from the circuit board.
  7. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 7 단계, 이미지 1/1
    • With the opening tool, pop up the screen assembly.
    • The screen is glued to the black cover. Use more force if needed.
  8. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 8 단계, 이미지 1/1
    • As in step 5, push up the brown locking mechanism of the remaining cable.
    • Unplug the picture cable.
  9. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 9 단계, 이미지 1/1
    • Turn the circuit board over and with a soldering gun remove the two wires on each end.
    • Use a screwdriver to pull the loosened wire away.
  10. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 10 단계, 이미지 1/1
    • With the wires no longer holding the circuit board and screen together, remove and replace the broken screen.
결론
Gyozo Aba Hivatal
회원 가입일: 01/21/15
561 평판
안내서 5개 작성하였습니다
USF Tampa, Team 6-4, Brown Winter 2015 USF Tampa, Team 6-4, Brown Winter 2015 회원
USFT-BROWN-W15S6G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 351
