주요 콘텐츠로 건너뛰기
Air Blasters Tek Six Barrel Replacement
필요한 것
  1. Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: 1 단계, 이미지 1/3 Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: 1 단계, 이미지 2/3 Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: 1 단계, 이미지 3/3
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: 2 단계, 이미지 1/3 Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: 2 단계, 이미지 2/3 Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: 2 단계, 이미지 3/3
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Barrel Replacement, Take the main body apart: 3 단계, 이미지 1/3 Air Blasters Tek Six Barrel Replacement, Take the main body apart: 3 단계, 이미지 2/3 Air Blasters Tek Six Barrel Replacement, Take the main body apart: 3 단계, 이미지 3/3
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Barrel Replacement, Remove the trigger: 4 단계, 이미지 1/3 Air Blasters Tek Six Barrel Replacement, Remove the trigger: 4 단계, 이미지 2/3 Air Blasters Tek Six Barrel Replacement, Remove the trigger: 4 단계, 이미지 3/3
    • Remove the trigger, lifting from the bottom and pulling it out from under the metal pin.
  5. Air Blasters Tek Six Barrel Replacement, Removing the barrel: 5 단계, 이미지 1/3 Air Blasters Tek Six Barrel Replacement, Removing the barrel: 5 단계, 이미지 2/3 Air Blasters Tek Six Barrel Replacement, Removing the barrel: 5 단계, 이미지 3/3
    • Lift the barrel, pulling it out from under the black trigger catch
결론
Joshua Taylor
회원 가입일: 09/22/14
118 평판
안내서 1개 작성함
USF Tampa, Team 3-1, Brown Fall 2014 USF Tampa, Team 3-1, Brown Fall 2014 회원
USFT-BROWN-F14S3G1
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
I don't remember this blaster's shell as being held closed by solvent weld or catches - why is the "iFixit" pry-tool necessary?
Arasin Staubly - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 440
