주요 콘텐츠로 건너뛰기
Air Blasters Tek Six Plunger Replacement
필요한 것
  1. Air Blasters Tek Six Plunger Replacement, Remove screws of the grey slider: 1 단계, 이미지 1/3 Air Blasters Tek Six Plunger Replacement, Remove screws of the grey slider: 1 단계, 이미지 2/3 Air Blasters Tek Six Plunger Replacement, Remove screws of the grey slider: 1 단계, 이미지 3/3
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Plunger Replacement, Remove screws in main  body: 2 단계, 이미지 1/3 Air Blasters Tek Six Plunger Replacement, Remove screws in main  body: 2 단계, 이미지 2/3 Air Blasters Tek Six Plunger Replacement, Remove screws in main  body: 2 단계, 이미지 3/3
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Plunger Replacement, Take the main body apart: 3 단계, 이미지 1/3 Air Blasters Tek Six Plunger Replacement, Take the main body apart: 3 단계, 이미지 2/3 Air Blasters Tek Six Plunger Replacement, Take the main body apart: 3 단계, 이미지 3/3
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Plunger Replacement, Remove screw holding the bottom spring to the air system: 4 단계, 이미지 1/1
    • Using a screwdriver, remove the 7.5 mm phillips 00 screw holding the bottom spring to the air system.
  5. Air Blasters Tek Six Plunger Replacement, Remove metal pin: 5 단계, 이미지 1/3 Air Blasters Tek Six Plunger Replacement, Remove metal pin: 5 단계, 이미지 2/3 Air Blasters Tek Six Plunger Replacement, Remove metal pin: 5 단계, 이미지 3/3
    • Carefully grab the metal pin keeping the air system and top spring stationary, and slide it outwards. This will release the air system with the plunger completely.
  6. Air Blasters Tek Six Plunger Replacement, Remove air system screw: 6 단계, 이미지 1/1
    • Using a screwdriver, remove the 5.2 mm phillips 00 screw holding the air system to the body of the blaster.
  7. Air Blasters Tek Six Plunger Replacement, Take the air system out: 7 단계, 이미지 1/3 Air Blasters Tek Six Plunger Replacement, Take the air system out: 7 단계, 이미지 2/3 Air Blasters Tek Six Plunger Replacement, Take the air system out: 7 단계, 이미지 3/3
    • Grab the whole air system and carefully take it out of the main body of the blaster.
  8. Air Blasters Tek Six Plunger Replacement, Remove plunger: 8 단계, 이미지 1/3 Air Blasters Tek Six Plunger Replacement, Remove plunger: 8 단계, 이미지 2/3 Air Blasters Tek Six Plunger Replacement, Remove plunger: 8 단계, 이미지 3/3
    • Now, grab the gray plunger with your hand and slide it outwards to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alfredo Antolinez
회원 가입일: 09/22/14
347 평판
안내서 3개 작성하였습니다
USF Tampa, Team 3-1, Brown Fall 2014 USF Tampa, Team 3-1, Brown Fall 2014 회원
USFT-BROWN-F14S3G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 717
