주요 콘텐츠로 건너뛰기
Air Blasters Tek Six Reload Slider Spring Replacement
필요한 것
  1. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: 1 단계, 이미지 1/3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: 1 단계, 이미지 2/3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: 1 단계, 이미지 3/3
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: 2 단계, 이미지 1/3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: 2 단계, 이미지 2/3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: 2 단계, 이미지 3/3
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: 3 단계, 이미지 1/3 Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: 3 단계, 이미지 2/3 Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: 3 단계, 이미지 3/3
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: 4 단계, 이미지 1/3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: 4 단계, 이미지 2/3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: 4 단계, 이미지 3/3
    • Carefully grab the metal pin keeping the air system and top spring, and slide it outwards. This will release the air system with the plunger completely.
  5. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw holding the top spring to reload slider: 5 단계, 이미지 1/2 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw holding the top spring to reload slider: 5 단계, 이미지 2/2
    • Using a screwdriver, remove the 7.5 mm phillips 00 screw holding the top spring to the reload slider.
결론
Alfredo Antolinez
회원 가입일: 09/22/14
347 평판
안내서 3개 작성하였습니다
USF Tampa, Team 3-1, Brown Fall 2014 USF Tampa, Team 3-1, Brown Fall 2014 회원
USFT-BROWN-F14S3G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 459
