주요 콘텐츠로 건너뛰기
Air Conditioning Thermostat Replacement
필요한 것
  1. Air Conditioning Thermostat Replacement, Turn Off the Power: 1 단계, 이미지 3개 중 1개 Air Conditioning Thermostat Replacement, Turn Off the Power: 1 단계, 이미지 3개 중 2개 Air Conditioning Thermostat Replacement, Turn Off the Power: 1 단계, 이미지 3개 중 3개
    • Before you begin, locate the circuit breaker switchboard for the housing unit.
    • Find the air conditioning breaker that’s typically labeled inside the breaker's panel cover.
    • Turn off the electrical breaker switch that supplies the air conditioning thermostat.
  2. Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: 2 단계, 이미지 3개 중 1개 Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: 2 단계, 이미지 3개 중 2개 Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: 2 단계, 이미지 3개 중 3개
    • Separate the thermostat casing off of the wall plate. It should come off easily using your hands, but a pair of pliers can be used if it's being stubborn.
    • Take a picture using your phone's camera of the color-coded wiring, so it will be easier to re-attach the wiring to the new thermostat.
  3. Air Conditioning Thermostat Replacement: 3 단계, 이미지 3개 중 1개 Air Conditioning Thermostat Replacement: 3 단계, 이미지 3개 중 2개 Air Conditioning Thermostat Replacement: 3 단계, 이미지 3개 중 3개
    • Use the Flathead 3/32" 2.5 mm Screwdriver to separate the color coded wiring.
    • Use the Phillips or flathead screwdriver to separate and un-wrap each of the color coded wires. (For example: notice the yellow wire)
    • Use the Phillips or flathead screwdriver depending on the type of model, to remove the Phillips #0 Plus screw, in order to remove the base plate.
  4. Air Conditioning Thermostat Replacement: 4 단계, 이미지 3개 중 1개 Air Conditioning Thermostat Replacement: 4 단계, 이미지 3개 중 2개 Air Conditioning Thermostat Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the old base plate of the thermostat.
    • Screw in the new base plate of the Thermostat using the Phillips or flathead screwdriver to screw in the Phillips #0 Plus screw drive.
    • Using the screwdriver; reconnect the color-coded wring based on the photo taken with your camera. (For example: Notice the yellow wiring)
  5. Air Conditioning Thermostat Replacement: 5 단계, 이미지 2개 중 1개 Air Conditioning Thermostat Replacement: 5 단계, 이미지 2개 중 2개
    • Use your fingers to wrap the copper around the terminal slots, Use your Flathead 3/32" 2.5 mm Screwdriver to tighten the terminal slots. (For example: Notice the yellow wiring)
    • Fasten the terminal slots using your Phillips Flathead 3/32" 2.5 mm Screwdriver.
  6. Air Conditioning Thermostat Replacement: 6 단계, 이미지 2개 중 1개 Air Conditioning Thermostat Replacement: 6 단계, 이미지 2개 중 2개
    • Place the new thermostat casing over the base plate.
    • Snap on the thermostat casing.
  7. Air Conditioning Thermostat Replacement: 7 단계, 이미지 3개 중 1개 Air Conditioning Thermostat Replacement: 7 단계, 이미지 3개 중 2개 Air Conditioning Thermostat Replacement: 7 단계, 이미지 3개 중 3개
    • Locate the circuit breaker switchboard for the housing unit.
    • Locate the air conditioning electrical breaker switch.
    • Turn on the electrical breaker switch that the air conditioning thermostat supplies.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Genesis
회원 가입일: 03/01/17
163 평판
안내서 1개를 작성함
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 회원
USFSM-STEWART-S17S1G1
19 회원들
안내서 22개를 작성함
댓글 한 개
ما هو السبب خروج علامت E3 في اسبلت westtin
السبلت ٣ طن عمودي
Hassan Alkanan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 39
전체 시간: 1,817
