주요 콘텐츠로 건너뛰기
Air Filter Replacement
  1. Air Filter Replacement, Filter: 1 단계, 이미지 1개 중 1개
    • Locate air filter grille
    • This is usually found near the thermostat
    • Some systems contain multiple filters
    • Not all duct systems have a filter grill. Some are filtered at the air handling appliance
  2. Air Filter Replacement, Open the grill: 2 단계, 이미지 2개 중 1개 Air Filter Replacement, Open the grill: 2 단계, 이미지 2개 중 2개
    • Pull out both latches so that they are perpendicular to the wall
    • Pull grill open from top center
  3. Air Filter Replacement, Remove used filter: 3 단계, 이미지 1개 중 1개
    • Remove the dirty filter
    • If you aren't sure if the filter is ready to be changed just remember this is what cleans the air you are breathing.
    • Never wash or reuse a disposable filter
    • Pleated filters remove more dirt from the air than fiberglass filters. But their density restricts the air flow more. This can create problems in some systems. Experiment with both and see which is best for you and your system.
    • Filters should be checked every 30 days on residential applications and every 15 days on commercial applications.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
gsdfert34f2efse34
회원 가입일: 08/06/15
43 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 368
