주요 콘텐츠로 건너뛰기
Air Hog Smash Bots Front Panel Replacement
필요한 것
  1. Air Hog Smash Bots Front Panel Replacement, Front Panel: 1 단계, 이미지 1/2 Air Hog Smash Bots Front Panel Replacement, Front Panel: 1 단계, 이미지 2/2
    • Take out your controller and access to the back of the controller.
  2. Air Hog Smash Bots Front Panel Replacement: 2 단계, 이미지 1/1
    • Remove the screw on the battery lid. Using the Hex 4 socket and PH #0 bit, remove the 8 mm screw.
  3. Air Hog Smash Bots Front Panel Replacement: 3 단계, 이미지 1/1
    • Remove the 2 AAA batteries.
  4. Air Hog Smash Bots Front Panel Replacement: 4 단계, 이미지 1/2 Air Hog Smash Bots Front Panel Replacement: 4 단계, 이미지 2/2
    • Using the Hex 4 socket and PH #0 bit, remove the four 8 mm screws on the panel.
  5. Air Hog Smash Bots Front Panel Replacement: 5 단계, 이미지 1/2 Air Hog Smash Bots Front Panel Replacement: 5 단계, 이미지 2/2
    • Use the plastic opening tool to disconnect the front and back parts of the panel.
    • Some of the internal components may be displaced when opening the controller.
결론
Jiani Xie
회원 가입일: 02/08/16
173 평판
안내서 1개 작성함
IUPUI, Team 1-1, Baechle Spring 2016 IUPUI, Team 1-1, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S1G1
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 192
