주요 콘텐츠로 건너뛰기
AirCard 770S Back Case Replacement
필요한 것
  1. AirCard 770S Back Case Replacement, Back Case: 1 단계, 이미지 1/1
    • Hold the device with an open corner available and facing you.
  2. AirCard 770S Back Case Replacement: 2 단계, 이미지 1/1
    • Using your finger, pry open any of the four corners of the back case of your AirCard 770S, until you see the back case disconnect from the device.
  3. AirCard 770S Back Case Replacement: 3 단계, 이미지 1/1
    • Lift open the back case and remove it from the device.
    • In order to put a new back case on, make sure to align the white nobs found on the back cover, so that you do not force the case on and cause any damage to the device.
결론
Caitlin Little
회원 가입일: 10/08/18
437 평판
안내서 3개 작성하였습니다
Marist, Team S1-G2, Chaterdon Fall 2018 Marist, Team S1-G2, Chaterdon Fall 2018 회원
MARS-CHATERDON-F18S1G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 174
