주요 콘텐츠로 건너뛰기
AirPods Pro 1st Generation Ear Tips Replacement
동영상 개요
  1. AirPods Pro 1st Generation Ear Tips Replacement, Flip silicone earbud tip out: 1 단계, 이미지 1개 중 1개
    • Carefully pop out (or flip out) the ear tip of your AirPods Pro, prior to trying to remove them. This will ensure that you avoid accidentally ripping the delicate end of the AirPod Pro ear tip.
  2. AirPods Pro 1st Generation Ear Tips Replacement, Pull off ear tip from the base: 2 단계, 이미지 1개 중 1개
    • Don't rip the ear tip off using the end. Make sure you gently, but firmly pull the AirPod Pro ear tip from the earbud close to where it connects. It takes a little force, so don't be afraid to pull it out.
  3. AirPods Pro 1st Generation Ear Tips Replacement, Snap on new ear tips: 3 단계, 이미지 1개 중 1개
    • Align the new ear tip so that either the "L" or the "R" align with the black stripe on the AirPods Pro earbuds.
    • Snap in the new ear tip. (You should hear it snap.)
    • Fold back the silicon ear tip to the normal position
    • Don't misplace the AirPods Pro ear tips you just took out. You never know when you'll need them in a pinch.
  4. AirPods Pro 1st Generation Ear Tips Replacement, Ear Tip Fit Test: 4 단계, 이미지 1개 중 1개
    • Try Apple's ear tip fit test to see if your buds fit correctly and if they work well with your ears. If it tells you to change it, try a smaller or bigger one out by repeating all steps over.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
tayola
회원 가입일: 07/21/22
9,478 평판
안내서 44개를 작성함
Kid fixers Kid fixers 회원
Community
183 회원들
안내서 256개를 작성함
댓글 4개
Doesn’t work, both tips stuck firmly. Thinking of using small screwdriver to pull it off. Using AirPods Pro 2. Change right one easily, but the lady one is stubborn. Now the right one is stubborn as well
Vitali Vitali - 답글
Hello. The procedures should be pretty straightforward. Make sure they are aligned and try to use official ear tips. When buying replacements, make sure you bought the gen 2 tips, not the gen 1. Idk if they are the same thing or not, but see if that will work. If not, ask your question in the answers forum and see if someone can help you. It may be a problem with the connector or clip mechanism.
tayola -
My airbuds not support charging please help me
Khan - 답글
Meine Aufsätze passen nicht auf die AirPods, hab’s einmal auf Amazon bestellt und einmal bei Apple
Sophie Tillner - 답글
댓글 쓰기
조회 통계:
지난 24시간: 26
지난 7일: 168
지난 30일: 695
전체 시간: 31,201
