소개
Replacing the power supply on the AirPort Extreme A1521 takes a few steps. Once you get to the second to last step you need to be careful and not touch the black cylinders. They are capacitors and could give you a shock.
필요한 것
Using a metal spudger, gently pry the cover off the bottom of the device.
To detach the small clips from the connectors, place the flat end of the plastic spudger underneath the clip and gently lever it away from the center of the device.
To detach the large clip from its connector, place the flat end of the spudger on the clip and lever it upward out of the connector.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 4개
When removing the fan pay attention to the cable. It is glued down with sticky tape and is routed beneath the rubber seal that mates against the case. You may want to remove the power supply cover first since the cable for the fan is routed beneath its cover. But once the power supply fasteners are removed the power supply is dangling from its cables so be careful to relieve the strain.
Splendid! It worked! I'm so happy. The old fan did really have some slackness and the new one makes no sound. Thanks for describing how to change the fan.
I replaced the power supply but the router still does turn on, any advice?
Jonathan S - 답글
