주요 콘텐츠로 건너뛰기
AirPort Time Capsule A1409 HDD Replacement
  1. AirPort Time Capsule A1409 HDD Replacement, Hard Disk Drive: 1 단계, 이미지 3개 중 1개 AirPort Time Capsule A1409 HDD Replacement, Hard Disk Drive: 1 단계, 이미지 3개 중 2개 AirPort Time Capsule A1409 HDD Replacement, Hard Disk Drive: 1 단계, 이미지 3개 중 3개
    • Put the unit upside down and take off the rubber bottom cover. It is better to start at a corner.
    • Rubber becomes brittle as it ages. Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
  2. AirPort Time Capsule A1409 HDD Replacement: 2 단계, 이미지 3개 중 1개 AirPort Time Capsule A1409 HDD Replacement: 2 단계, 이미지 3개 중 2개 AirPort Time Capsule A1409 HDD Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the # 10 Phillips # 00 screws that hold the Time Capsule's lower metal bracket.
    • Open to the left leaving the network connectors on that side. Do not open it fully to avoid breaking the fan cable.
  3. AirPort Time Capsule A1409 HDD Replacement: 3 단계, 이미지 2개 중 1개 AirPort Time Capsule A1409 HDD Replacement: 3 단계, 이미지 2개 중 2개
    • With the tip of a spudger carefully remove the fan connector then remove the metal bottom cover.
  4. AirPort Time Capsule A1409 HDD Replacement: 4 단계, 이미지 3개 중 1개 AirPort Time Capsule A1409 HDD Replacement: 4 단계, 이미지 3개 중 2개 AirPort Time Capsule A1409 HDD Replacement: 4 단계, 이미지 3개 중 3개
    • Find the temperature sensor on the surface of the hard disk.
    • Carefully remove the tape covering the temperature sensor.
  5. AirPort Time Capsule A1409 HDD Replacement: 5 단계, 이미지 2개 중 1개 AirPort Time Capsule A1409 HDD Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the clip that holds the temperature sensor and remove both.
  6. AirPort Time Capsule A1409 HDD Replacement: 6 단계, 이미지 2개 중 1개 AirPort Time Capsule A1409 HDD Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the hard drive a bit without pulling too hard to not cause damage to the power and data connectors of the hard disk. Removing the power connector from the hard drive
    • Remove the data connector from the hard disk.
  7. AirPort Time Capsule A1409 HDD Replacement: 7 단계, 이미지 2개 중 1개 AirPort Time Capsule A1409 HDD Replacement: 7 단계, 이미지 2개 중 2개
    • Once we have the disc out of the Time Capsule, we remove the 4 Phillips head # 00 pillars and place them in the new unit.
결론
To reassemble your gadget, follow these instructions backward.
다른 50명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
es en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
David Medrano
회원 가입일: 12/22/13
1,786 평판
안내서 1개를 작성함
Tecnico Center Teatinos, S.L. Tecnico Center Teatinos, S.L. 회원
Business
1 회원
안내서 4개를 작성함
15가이드 댓글
I replaced a dead drive in about 30 mins following these instructions. The steps are clear, straight forward and the photos were extremely helpful. Many thanks as I now have a renovated AirPort Time Capsule.
Peter Long - 답글
I just replaced the 2 TB WDC Green with a WD Red Pro 4 TB with this guide in less than 30 min. Except for the fan cable it was a cake walk.
Alex Senger - 답글
Successfully upgraded my A1409 to a Western Digital - WD100PURZ - 5400 RPM Class SATA 6 Gb/s 256MB Cache 3.5. There are two additional steps: (a), there is a rubber strip around the original drive that reduces noise and protects the drive, gently remove from the original drive and place on the new drive; (b) once the rubber strip is on the drive, it is hard to get into place, angle the drive towards the connector side, and press in.
Brunob00 - 답글
12 TB WD RED (inbuilt version WD120EMAZ) just confirmed for 1409 (G4 version).
you are welcome
AD G - 답글
Hola. Reemplacé el disco con toda facilidad pero, desgraciadamente, la Utilidad AirPort no lo está reconociendo ni consigue borrarlo para activarlo. El HD nuevo es un WD Red de 10 TB. Si alguien puede ayudarme a resolver el problema, agradezco mucho.
I MM - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 104
지난 30일: 432
전체 시간: 29,048
