소개
When the battery warning alarm cannot be properly reset from the simple troubleshooting and the voltage from the battery is severely low, it may be necessary to replace the battery. This repair guide will aid the user through the process of replacing the battery in the ventilator.
The repair guide information is mentioned in following sections of the user repair manual as well:
· Chapter 2 – 2.1.1 Cleaning the Device
· Chapter 2 – 2.4.1 Opening and Closing
· Chapter 5 – 5.1.1 Removal/Installation of the Battery
필요한 것
Before you start the battery replacement process, make sure that the device has been placed in a clean and open environment.
Perform the final inspection procedures by confirming that every screw is secure before putting back into service.
